Overview & system prep
Virtual machines (VMs) allow you to run full operating systems, such as Windows, macOS, or Linux, on your Unraid server, side-by-side with Docker containers.
VMs are ideal for:
- Running applications that require a full OS or are unavailable as containers.
- Assigning dedicated hardware to guest systems, such as GPUs or USB devices.
- Testing, development, gaming, or running legacy software.
- Hosting multiple isolated environments for different workloads.
For a list of operating systems tested with Unraid, see the VM Setup page.
Under the hood: Expand to learn more about the technology stack behind Unraid virtualization
Unraid’s virtualization stack is designed to be flexible and high-performing, utilizing several open-source technologies to support effective virtual machine (VM) management. This overview explains the key components and their interaction in a user-friendly manner.
Core technologies
Technology | What it does | Why it matters |
KVM | Acts as the hypervisor built into the Linux kernel. | Allows Unraid to run VMs smoothly with hardware acceleration and minimal overhead. |
QEMU | Emulates the essential hardware (like motherboard, CPU, and controllers) for VMs. | Works alongside KVM to create a complete virtual environment for the guest operating systems. |
Libvirt | Manages VM definitions, as well as storage and network interfaces. | Stores VM configurations in libvirt.img and provides a consistent management API. |
VNC | Offers remote graphical access to VMs. | Enables interaction with VMs from any device using a browser or VNC client. |
VirtIO | Provides high-performance paravirtualized drivers for network and disk devices. | Enhances VM speed and efficiency, requiring VirtIO drivers installed in the guest OS. |
VirtFS (9p ) | Facilitates file system sharing between the host and Linux-based guests. | Useful for development and advanced file sharing needs. |
HVM | Supports hardware-assisted virtualization (Intel VT-x, AMD-V). | Necessary for running VMs with full hardware acceleration. |
VFIO & IOMMU | Allow direct PCI device passthrough to VMs (such as GPU and USB devices). | Essential for achieving near-native performance and maintaining security isolation. |
How Unraid implements VM support
- KVM/QEMU: Unraid’s virtualization is fundamentally based on KVM and QEMU, providing robust VM hosting capabilities.
- Libvirt: VM definitions are stored as XML files in
libvirt.img
(typically found in thesystem
share). - Default shares:
domains
: Holds VM virtual disk images.isos
: Contains installation ISOs and driver images.system
: Storeslibvirt.img
and other critical system files.- All default to Use Cache: Prefer for optimal performance.
- VNC: Unraid features a built-in NoVNC client for easy browser-based access to VMs, with the option to use external VNC clients as needed.
Requirements
To run VMs on Unraid, your system must meet the following requirements:
Component | Minimum requirement | Recommended for VMs & GPU passthrough |
CPU | 64-bit, 4 cores, 2.4 GHz+ (Intel/AMD) | 8+ cores, 3.0 GHz+ (Intel Core i7/i9, AMD Ryzen 7/9, or newer) |
Virtualization | HVM (Intel VT-x or AMD-V) | HVM + IOMMU (Intel VT-d or AMD-Vi) |
RAM | 8 GB | 16 GB or more (add RAM for each active VM) |
Storage | SSD/NVMe for VM disks | High-end NVMe for best performance |
Network | Gigabit Ethernet (PCIe recommended) | 2.5G/10G Ethernet for demanding workloads |
GPU (optional) | Modern NVIDIA RTX (recommended) or AMD Radeon RX | RTX 3000/4000 series (NVIDIA recommended for better passthrough compatibility) |
NVIDIA GPUs are generally recommended for VM passthrough due to better compatibility and reliability. AMD GPUs can be more challenging to pass through, and some newer models (including RX 7000/9000 series) may not work reliably or at all with VMs. If you're planning to use GPU passthrough, consider NVIDIA options for the best experience.
Your motherboard BIOS must enable Hardware-assisted virtualization and IOMMU support. Look for settings labeled “Intel VT-x,” “Intel VT-d,” “AMD-V,” or “AMD-Vi.”
VM resources
VM type | RAM per VM | vCPUs per VM | Use case examples |
Virtual server | 1–2 GB | 1–2 | Lightweight Linux, utility VMs |
Virtual desktop | 4–8 GB | 2–4 | Windows 11, Ubuntu desktop, RDP |
Hybrid/gaming VM | 8–16 GB+ | 4–8+ | GPU passthrough, gaming, ML |
- Memory and CPU are only consumed while VMs are running.
- Plan for peak usage if running multiple VMs simultaneously.
- Always allocate resources based on guest OS and workload requirements.
HVM & IOMMU: What they enable
- HVM support
- IOMMU support
HVM (Hardware Virtual Machine), also known as Intel VT-x or AMD-V, enables your CPU to run virtual machines with hardware acceleration.
- Required for creating and running any VM on Unraid.
- Provides efficient CPU virtualization and better performance compared to software-only virtualization.
- Most modern CPUs (2015 and newer) include this feature.
IOMMU (Input/Output Memory Management Unit, also known as Intel VT-d or AMD-Vi) enables secure and efficient device passthrough to VMs.
- Required for assigning PCIe devices (GPUs, USB controllers, NVMe drives) directly to a VM.
- Provides memory isolation and protection, preventing devices from accessing unauthorized memory regions.
- Essential for GPU passthrough, advanced networking, and high-performance workloads.
In the WebGUI, click Info in the top menu.
- HVM support: Shows if hardware virtualization is present and enabled.
- IOMMU support: Shows if device passthrough is available and enabled.
Graphics device passthrough
Passing a GPU to a VM allows for near-native graphics performance, making it ideal for gaming, creative work, or machine learning.
- NVIDIA
- AMD
- All modern RTX (3000/4000 series) support passthrough and are recommended for the best performance.
- Quadro and some older GTX cards are also supported, but it's important to check for current driver compatibility.
- Radeon RX 6000 series are generally reliable for passthrough.
- RX 7000 series may have some unresolved issues; please check the Unraid forums for the latest compatibility reports.
- The AMD reset bug has mostly been resolved in recent models, but it's always a good idea to confirm with your hardware.
- Use OVMF (UEFI) for VMs with modern GPUs.
- Always use the latest Unraid version for improved hardware support.
- Technologies like NVIDIA Optimus may allow GPU passthrough for laptops or advanced setups, but results vary.
Hardware and driver compatibility changes rapidly. Before purchasing a GPU for passthrough, check the Unraid forums and vendor documentation for up-to-date reports and user experiences.
System preparation
Before you create virtual machines, complete these essential setup tasks to ensure your system is ready.
Adjust BIOS settings
To fully utilize Unraid's virtualization capabilities, your BIOS must enable hardware-assisted virtualization and I/O memory management. Look for settings labeled Virtualization, Intel VT-x, Intel VT-d, AMD-V, or AMD-Vi and set them to Enabled.
BIOS interfaces vary by manufacturer. Check your motherboard manual for the exact location of these settings.
Configure a network bridge
Virtual machines can connect to your network using one of two bridge types. Choose the one that best fits your needs:
Bridge type | Description | Use case |
Private NAT (virbr0) | Managed by libvirt. This option provides an internal DHCP server and an isolated subnet. VMs can access the internet and host file shares, but are isolated from other network devices. | Ideal for isolated VMs needing internet and host access but no LAN visibility. |
Public bridge (br0) | Managed by Unraid. This option connects VMs directly to your LAN, with IPs assigned by your router. MAC addresses are preserved for consistent IP assignment. | Best for VMs that should function as regular devices on your network, accessible from other devices. |
If your Unraid server is connected to Wi-Fi, using the Private NAT (virbr0) network bridge for your virtual machines is recommended. This is because Wi-Fi interfaces support only a single MAC address, which restricts the use of public bridges and custom network types. By utilizing the virbr0 bridge, your VMs will have complete network access through NAT, although they will not be directly accessible from other devices on your local area network (LAN). However, you can still access the VMs via VNC through the host.
- Enable the public bridge in Network settings → Enable bridging.
- Set your preferred bridge as the Default network bridge in VM settings. You may need to enable advanced view to see this option.
User shares for virtualization
Unraid creates two default user shares for virtualization:
isos
: This share stores installation media files for your VMs.domains
: This share holds virtual machine virtual disk images and configuration files.
Consider creating a separate share for VM backups to protect your data.
Share configuration recommendations
- Store active VM virtual disk images on a cache-only share for the best performance.
- Using SSDs in your cache pool significantly improves VM responsiveness.
- Cache usage for the
isos
share is optional.
Do not store active virtual machines on a share with Use cache set to Yes. This can cause VMs to be moved to the array during the Mover process, leading to degraded performance.
Set up virtualization preferences
Before you begin, ensure your system is ready for virtualization (see System preparation). Setting your virtualization preferences in Unraid helps ensure your virtual machines (VMs) are configured for optimal performance and compatibility.
To set your virtualization preferences:
- In the WebGUI, go to Settings → VM Manager.
- For Windows VMs:
- Download the latest stable VirtIO Windows drivers ISO from the official repository.
- Copy the VirtIO ISO file to your isos share.
- In VM Manager, use the file picker for VirtIO Windows Drivers ISO to select the ISO you just copied.
- (Optional) Override the default driver ISO for individual VMs in Advanced View.
- Select a default network bridge:
- Choose
virbr0
for a private network bridge, or select a public bridge (e.g.,br0
) created in Network Settings. - (Optional) Override the default network bridge for each VM in Advanced View.
- Choose
- PCIe ACS override (Advanced):
This setting is experimental and may affect system stability. Use with caution.
5. Click Apply to save your settings.
