Wake-on-LAN (WoL)
Wake-on-LAN (WOL) lets you remotely wake your Unraid server from a shutdown or sleep state by sending a "magic packet" over the network. This page will help you set up WoL for your local network.
Requirements
For WoL to work properly, make sure you meet the following requirements:
NIC support: Your network interface controller should support WoL; most modern NICs do.
BIOS/UEFI settings: Enable WoL in your motherboard's BIOS/UEFI under power management. Here are some common setting names:
Setting name Description Wake on LAN Generic WoL setting PME event wake-up For PCIe wake events Power on by PCI/PCIe devices Alternate name for WoL ErP ready Must be disabled for WoL to work -
Power connection: Ensure your server is plugged into a power source.
Network connection: Connect your server to your LAN with an Ethernet cable (WiFi WoL is not supported).
